System Administration
Monitoring​
Use docker stats to show CPU, memory, network read/writes, and total disk read/writes for running containers. Also use prometheus metrics to monitor individual container health (see: Metrics).
JVM​
Diagnosing JVM memory problems​
Output contains:
MC: Metaspace capacity (kB).
The output contains:
docker exec -it or-manager-1 /usr/bin/jcmd 1 GC.run
Install the JDK​
Performing a heap dump (jmap)​
Create heap dump​
Copy to Docker host​
Use scp to copy from Docker host to local machine​
scp {HOST}:~/dump.hprof ~
Performing a thread dump (jstack)​
Create thread dump​
scp {HOST}:~/threads.txt ~
Database​
This document summarises the database performance, storage footprint, and system efficiency of the OpenRemote instance before and after enabling TimescaleDB Hypercore compression features. It serves as a reference for System Administrators to understand the expected baselines, trade-offs, and critical maintenance thresholds.
Use the following docker command to access the database on the docker host:
docker exec -it openremote-postgresql-1 psql -U postgres
Datapoint retention​
Asset datapoints are kept indefinitely by default. To purge older datapoints, set the OR_DATA_POINTS_MAX_AGE_WEEKS environment variable on the manager to the number of weeks to keep; a value of 0 or less disables purging.
The purge runs weekly (first at around 03:00 after startup) and uses TimescaleDB's drop_chunks() to remove whole chunks of the asset_datapoint table. Chunks cover 7 days, so a chunk is only removed once all of its data is older than the retention period; datapoints can therefore be kept somewhat longer than configured.
Deprecated settings:
  • OR_DATA_POINTS_MAX_AGE_DAYS is still used when OR_DATA_POINTS_MAX_AGE_WEEKS is not set; the value is rounded up to whole weeks and a warning is logged.
  • The dataPointsMaxAgeDays attribute meta item no longer sets retention for individual attributes. If it is present on any attribute, its largest value (rounded up to whole weeks) is used as the minimum retention period for all datapoints. It can therefore only increase retention, and has no effect when purging is disabled. Remove it from attributes if you do not want it to extend retention.
Storage & compression​
Enabling Hypercore compression drastically reduced the database storage footprint by converting uncompressed historical row-data into highly compressed columnar structures.
MetricBefore HypercoreAfter HypercoreImprovement
Total DB Disk Size225.5 GB16.1 GB~93% Reduction
Datapoint Table Size219.6 GB10.0 GB~95% Reduction
Index Size130.8 GB3.4 GB~97% Reduction
Compression RatioN/A~61.8x-
SysAdmin Note: The massive reduction in index size occurs because TimescaleDB discards traditional B-Tree indexes on compressed chunks, relying instead on lightweight columnar metadata.
Memory & cache efficiency​
Prior to compression, the database footprint vastly exceeded the allocated Docker memory, resulting in severe disk thrashing and Out-Of-Memory (OOM) risks. Post-compression, the active data easily fits within PostgreSQL's shared_buffers.
Overall Cache Hit Ratio5.6%95.3%
Uncompressed Cache Hit Ratio0.5%91.9%
SysAdmin Note: A >95% cache hit ratio means PostgreSQL is serving almost all queries instantly from RAM. To maintain this efficiency, ensure that the Docker shm_size (Shared Memory) is appropriately configured to be slightly larger (e.g., +10-20%) than the PostgreSQL shared_buffers setting to prevent startup crashes.
Query performance benchmarks​
Query execution times were fundamentally transformed. Heavy historical aggregations that previously choked the database are now highly optimised, with a minor architectural trade-off for ultra-fast, single-point queries.
Query TypeExampleBefore (ms)After (ms)Change
Overall AverageAll Queries~4,359 ms~436 ms~90% Faster
Heavy Aggregation4hOF-kwMax_Daily_MinMaxAvg_30d44,442.0 ms583.9 ms98.6% Faster
Heavy Aggregation2pPI-power_Daily_MinMaxAvg_30d9,951.1 ms284.2 ms97.1% Faster
Heavy Aggregation4jp8-power_Daily_MinMaxAvg_30d7,815.3 ms158.4 ms97.9% Faster
Light Micro-Query4hOF-kwMin_Hourly_Avg_7d4.4 ms157.1 ms(Expected Trade-off)
SysAdmin Note:
  • The Win: Complex, multi-day historical aggregations improved by 97-98%, eliminating 40+ second query timeouts.
  • The Trade-off: Micro-queries taking <10ms previously will now take ~50-150ms. This is expected behavior; querying compressed chunks requires on-the-fly decompression CPU overhead to unpack the columnar data back into rows.
Critical maintenance guidelines​
Here's a summary of critical PostgreSQL memory settings:
PostgreSQL & Docker Memory Summary​
Setting / LimitScopePrimary PurposeHow it relates to Hypercore & Docker
Total Container RAMDocker LimitThe absolute physical ceiling.If the combined database footprint exceeds this, the Linux OOM killer crashes the container.
shm_sizeDocker LimitSets the maximum allowed size for the shared memory file system (/dev/shm).Must be set ~10-20% higher than shared_buffers so the database has permission to allocate its global cache.
shared_buffersGlobal Postgres CacheThe main memory pool where PostgreSQL caches active data.Holds the highly compressed Hypercore columnar blocks. Needs to fit entirely inside Docker's shm_size.
maintenance_work_memLocal Postgres MemoryA dedicated workspace for heavy background maintenance tasks.Critical for compression. Used to sort raw data before compressing it into chunks. If set too high, it causes an OOM crash.
work_memLocal Postgres MemoryWorkspace for everyday query operations (sorting, joining, grouping).Multiplies rapidly. It is allocated per operation. Used to temporarily decompress columnar chunks back into rows for user queries.
effective_cache_sizeQuery Planner HintEstimates how much RAM the Linux OS has left over for caching files.Does not allocate RAM. Helps the query planner decide the fastest way to scan compressed Hypercore blocks.
The Golden Rule: shared_buffers (Fixed) + maintenance_work_mem (Spiky) + work_mem (Highly Spiky) must never exceed the Total Container RAM.
To keep the instance healthy and prevent Docker crashes, you can follow these guidelines:
  1. Calculate largest uncompressed chunk size N (see pg_datapoint_largest_uncompressed_chunk metric or query or use approximate calculation ~1 million datapoints / week = 300MB)
  2. Calculate minimum RAM size P = (4 x N) = 1.2GB (Round up to 2GB here)
  3. Set shared_buffers at 25% RAM (0.25 x P) = 512MB
  4. Set shm_size (shared_buffers + ~20%) = ~614MB (Round up to a clean number 1GB)
  5. Set maintenance_work_mem (0.125 x P) = 250MB (Round up to a clean number 256MB)
  6. Set work_mem (1% x P) = 16MB (or larger if there are few concurrent connections)
  7. Set effective_cache_size (P - shared_buffers) = 1.5GB
  8. Actively monitor pg_hot_update_percent metric to attain a >90% HOT update percentage; tweak the asset table fillfactor to achieve this (default is set to: 90% as asset table is not significantly large)
Apply this config in docker compose yaml as follows (use environment variables for convenience:
services:
postgresql:
image: openremote/postgresql:${POSTGRESQL_VERSION:-latest-slim}
restart: always
# RAM limits and PostgreSQL memory settings should be set appropriately for the expected load (see documentation)
shm_size: ${OR_DB_SHM:-156mb}
deploy:
resources:
limits:
memory: ${OR_DB_RAM:-512M}
command:
- postgres
- -c
- shared_buffers=${OR_DB_SHARED_BUFFERS:-128MB}
- -c
- effective_cache_size=${OR_DB_CACHE_SIZE:-384MB}
- -c
- maintenance_work_mem=${OR_DB_MAINTENANCE_WORK_MEM:-56MB}
- -c
- work_mem=${OR_DB_WORK_MEM:-4MB}
Some simple guidelines​
  • Docker's shm_size must be sized appropriately. A simple rule of thumb is to take PostgreSQL shared_buffers and add a margin (10% or a flat 256MB); the shared_buffers must fit inside this size (NOTE: Docker sets this very low by default and this will cause problems for any reasonable size DB)
  • Do not run timescaledb-tune automatically on container startup. It may miscalculate limits if Docker's cgroup namespaces are restricted.
  • Best Practice: Run timescaledb-tune with explicit CPU and memory values to avoid known issues with the script not being able to figure out docker aware values itself timescaledb-tune --memory="2GB" --cpus="2" --dry-run, the dry-run setting ensures no changes are made to the configuration file and instead hardcode the tuned shared_buffers, effective_cache_size, maintenance_work_mem and work_mem directly into the docker-compose.yml command args.
  • The 25% Rule: The largest uncompressed chunk should never exceed 25% of the total Docker container RAM limit.
  • For a 2GB container limit, the pg_datapoint_largest_uncompressed_chunk metric must stay below 512 MB.
  • If chunks grow too large, the background compression worker will exhaust RAM during the sorting phase and trigger the Linux OOM killer. If this occurs, reduce the hypertable's chunk_time_interval via set_chunk_time_interval().
  • The asset table is constantly being updated (whenever an attribute event is written to the attributes JSONB column) this can cause excessive autovacuum executions and can be a significant bottleneck for large asset tables due to the way row updates are handled by PostgreSQL; HOT updates is an optimisation PostgreSQL uses to minimise this overhead and the asset table fillfactor can be tweaked to optimise this (default: 90%)
Backup/Restore​
  • Optional: Exclude datapoint records from the backup using the following command: docker exec or-postgresql-1 pg_dump -Fc openremote -f /tmp/db.bak --exclude-table-data='_timescaledb_internal._hyper_*'
  • Remove the backup from within the container: docker exec or-postgresql-1 rm /tmp/db.bak
  • SCP the backup off the source server onto the destination server: e.g. scp <HOST>:~/db.bak .
Recover failed update​
The openremote/postgresql container should handle automatic updates to the latest TimescaleDB version in the image and also auto migration to the major version of PostgreSQL in the image (note: you must incrementally go through each major version of the openremote/postgresql images i.e. you cannot go from 14.x to 17.x but must go 14.x -> 15.x -> 17.x [there is no 16.x image so this can be skipped]).
The PostgreSQL auto migration process will move PGDATA to a sub directory called old and create a new directory for the initialisation of the new major version DB, if the upgrade fails then you will need to manually handle the issue and move files back to the PGDATA folder like so:
docker exec --rm -it -v or_postgresql-data:/var/lib/postgresql/data --entrypoint=bash openremote/postgresql:latest-slim
mv -v data/old/* $PGDATA
rm -r data/new data/old
Attaching DB snapshot to an EC2 instance​
For data recovery or testing purposes, it may be desirable to attach a DB snapshot to an existing instance. The following steps explain how to do this using an AWS EC2 EBS snapshot of the Docker volumes.
New instance​
A volume based on a snapshot can be easily created and attached to a new EC2 instance using the Provision Host GitHub action or the provision_host.sh bash script directly.
Rollback an existing instance using AWS SSM​
When using the SSM documents provided in cloudformation-create-ssm-documents.yml the rollback process can be completed automatically in just a few minutes. This reduces the number of manual steps required and is therefore less error-prone. To start the rollback process, select the replace_volume SSM document from the AWS SSM console. The document requires only a few parameters to be filled in:
  • SnapshotId (The ID of the snapshot to restore from)
  • VolumeId (The ID of the EBS volume to replace with the snapshot)
  • DeleteVolume (Specifies whether the existing EBS volume should be deleted after replacement. Set to true to delete the volume or false to keep it.)
When executing the automation, AWS will perform several actions under the hood.
  1. Retrieve the instance details for the specified VolumeId
  2. Create a new EBS volume from the snapshot specified in SnapshotId
  3. Detach the current EBS volume and attach the newly created volume.
  4. Execute the attach_volume SSM automation. This automation runs several commands directly on the EC2 instance to mount the volume and update the fstab file. The tag attached to the EBS volume is also updated to ensure that AWS Data Lifecycle Manager (DLM) targets the volume when creating daily and weekly backups.
  5. Based on the DeleteVolume parameter, the original EBS volume is either deleted or retained as backup.
Manually rollback an existing instance​
  1. Create a new EBS volume from the EBS snapshot
  2. Attach the new EBS volume to the existing EC2 instance using the AWS console or the aws ec2 attach-volume command
  3. Check the EBS volume is attached as a disk using lsblk (assuming it is attached as /dev/nvme2n1 for remaining steps)
  4. Mount the EBS volume sudo mount -t xfs -o nouuid /dev/nvme2n1 /mnt/snapshot
  5. Change PostgreSQL data volume permissions sudo chown -R 70:70 /mnt/snapshot/or_postgresql-data/_data
  6. Start a temporary PostgreSQL instance to connect to the snapshot DB. Locate the PostgreSQL data volume shown by ls /mnt/snapshot (generally called or_postgresql-data) and use that name in the -v /mnt/snapshot/<YOUR_POSTGRES_VOLUME_NAME>/_data:/var/lib/postgresql/data mount below.
    sudo docker run -d \
    --rm \
    --name temp_recovery_db \
    -p 5433:5432 \
    -e POSTGRES_PASSWORD=postgres \
    -v /mnt/snapshot/<YOUR_POSTGRES_VOLUME_NAME>/_data:/var/lib/postgresql/data \
    -v /tmp:/export \
  7. Wait for the DB to be ready. When starting from a large snapshot, this can take a while; check the Docker container logs for the DB-ready message.
  8. Extract/Analyse the data as required either by:
    • Exec'ing into the container docker exec -it temp_recovery_db psql -U postgres -d openremote
    • Modifying the Manager and Keycloak DB settings to connect to the temporary DB on port 5433.
Useful resources​
Useful queries​
Refer to the Query Exporter configuration file for useful DB monitoring queries.
Adjust asset table fillfactor​
ALTER TABLE asset SET (fillfactor = 80);
Clear syslogs older than 1 day​
Export all asset data points​
Export a subset of asset data points (asset and direct child assets)​
Delete all asset datapoints older than N days​
On compressed chunks a delete is slow because the affected chunks must be decompressed. Dropping whole chunks is much faster, but only removes chunks whose data is entirely older than the given interval:
select drop_chunks('asset_datapoint', older_than => INTERVAL '4 weeks');
Accessing the exported CSV file​
docker cp <PROJECT_NAME>-postgresql-1:/deployment/datapoints.csv ./
Importing asset data points​
Drop temp table:
DROP TABLE tmp_table;
Remove consoles that haven't registered for more than N days​
DELETE FROM asset a
Count notifications with specific title sent to consoles (Android/iOS) in past N days​
SELECT count(*)
FROM notification n
Count notifications with specific title sent to consoles (Android/iOS) and acknowledged by:​
Closing/Dismissing​
SELECT count(*)
FROM notification n
n.acknowledgement = 'CLOSED';
Clicking the notification​
SELECT count(*)
FROM notification n
n.acknowledgement IS null;
Clicking a specific action button​
select count(*)
FROM notification n
Data migration​
DB Functions​
https://github.com/openremote/core/blob/main/manager/src/main/resources/org/openremote/manager/setup/database
Examples​
Add/Update meta items to specific attribute of asset(s)​
FROM asset a WHERE...;
Remove meta items from specific attribute of asset(s)​
Remove attributes from specific asset(s)​
Add attribute to specific asset(s) (with meta items)​
Add attribute to specific asset(s) (without meta items)​
Proxy​
SSH tunnel for proxy stats​
HAProxy stats web page is only accessible on localhost in our default config, this can be tunnelled to your local machine to allow access at http://localhost:8404/stats:
ssh -L 8404:localhost:8404 <HOST>
OpenRemote Manager​
Insert a different manager_config.json file​
docker exec <PROJECT_NAME>-manager-1 mkdir -p /deployment/manager/app
docker cp ./manager_config.json <PROJECT_NAME>-manager-1:/deployment/manager/app/manager_config.json
Insert an .mbtiles file for applying a different map​
docker exec <PROJECT_NAME>-manager-1 mkdir -p /deployment/map
docker cp ./<FILE_NAME>.mbtiles <PROJECT_NAME>-manager-1:/deployment/map/mapdata.mbtiles
Docker​
Cleaning up Docker images, containers, and volumes​
Working with Docker might leave exited containers and untagged images. cleanup using (use with caution):
docker volume prune -a
docker image prune -a
Restart exited containers (without using docker compose up)​
  • docker start <PROJECT_NAME>-postgresql-1
  • docker start <PROJECT_NAME>-keycloak-1
  • docker start <PROJECT_NAME>-map-1 (only if there is a map container)
  • docker start <PROJECT_NAME>-manager-1
  • docker start <PROJECT_NAME>-proxy-1
Using Docker Compose​
  • docker compose -f <PROFILE> pull <SERVICE> <SERVICE>... - Force pull requested services from Docker Hub, if no services specified then all services will be pulled (e.g. docker compose -f profile/manager.yml pull to pull all services)
  • docker compose -f <PROFILE> build <SERVICE> <SERVICE>... - Build/Rebuild requested services, if no services specified then all services will be built
  • docker compose -f <PROFILE> up <SERVICE> <SERVICE>... - Creates and starts requested services, if no services specified then all services will be created and started (also auto attaches to console output from each service use -d to not attach to the console output)
  • docker compose -f <PROFILE> up --build <SERVICE> <SERVICE>... - Creates and starts requested services but also forces building the services first (useful if the source code has changed as Docker Compose will not be aware of this change and you would otherwise end up deploying 'stale' services)
  • docker compose -f <PROFILE> down <SERVICE> <SERVICE>... - Stops and removes requested services, if no services specified then all services will be stopped and removed. Sometimes the shutdown doesn't work properly and you have to run down again to completely remove all containers and networks.
  • When deploying profiles you can provide a project name to prefix the container names (by default Docker Compose will use the configuration profile's folder name); the project name can be specified with the -p argument using the CLI:
docker compose -p <your_project_name> -f <profile> -f <profile_override> up -d <service1> <service2> ...
Shell​
Enabling bash auto-completion​
brew install bash-completion
fi
