Preview a configuration template import
POST
/asset/:assetId/configurationTemplate/import
Validates the document, matches its attributes against the draft by name and type, and returns the compatibility report together with the draft attributes holding the imported metadata. Metadata that grants access or links attributes is ignored, and the draft keeps its own. Nothing is stored; the client applies the patch after the user confirms.
Request​
Responses​
The request completed successfully
