Do protocol asset import
POSThttps://demo.openremote.io/api/master/agent/assetImport/:agentId
asset
Possible values: non-empty
and <= 1023 characters
and <= 255 characters
Possible values: [numeric
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
, 2-digit
, full
, long
, medium
, short
, narrow
"asset": {
"accessPublicRead": true,
"parentId": "string",
"type": "string",
"path": [
"string"
"delegate": {}
"children": [
null
curl -L 'https://demo.openremote.io/api/master/agent/assetImport/:agentId' \
-d '{
"contents": "string",
"binary": true
Click the Send API Request
button above and see the response here!
