Retrieve all node definitions by type
GET/flow/:type
type stringrequired
Possible values: [INPUT, PROCESSOR, OUTPUT, THEN]
typestring
position
xfloat
yfloat
size
xfloat
yfloat
internals
picker
typestring
Possible values: [TEXT, MULTILINE, NUMBER, DROPDOWN, DOUBLE_DROPDOWN, CHECKBOX, ASSET_ATTRIBUTE, COLOR]
options
valueobject
valueobject
inputs
typestring
Possible values: [NUMBER, STRING, BOOLEAN, TRIGGER, COLOR, ANY]
nodeIdstring
indexint32
outputs
typestring
nodeIdstring
indexint32
displayCharacterstring
