Version: 1.2.0
Retrieve the available meta item descriptors
GET
/model/metaItemDescriptors
    parentId string
    MetaItemDescriptorObject
  • Array [
  • messagestring
    typestringrequired
  • format
    useGroupingboolean
    minimumIntegerDigitsint32
    minimumFractionDigitsint32
    maximumFractionDigitsint32
    minimumSignificantDigitsint32
    maximumSignificantDigitsint32
    asBooleanboolean
    asDateboolean
    asSliderboolean
    resolutionnumber
    dateStylestring
    timeStylestring
    dayPeriodstring
    hour12boolean
    iso8601boolean
    weekdaystring
    erastring
    yearstring
    monthstring
    weekstring
    daystring
    hourstring
    minutestring
    secondstring
    fractionalSecondDigitsint32
    timeZoneNamestring
    momentJsFormatstring
    asNumberboolean
    asOnOffboolean
    asPressedReleasedboolean
    asOpenClosedboolean
    asMomentaryboolean
    multilineboolean
    unitsstring[]
    arrayDimensionsint32
    metaUseOnlyboolean
    jsonTypestring
  • Array [
  • messagestring
    typestringrequired
  • format
    useGroupingboolean
    asBooleanboolean
    asDateboolean
    asSliderboolean
    resolutionnumber
    dateStylestring
    timeStylestring
    dayPeriodstring
    hour12boolean
    iso8601boolean
    weekdaystring
    erastring
    yearstring
    monthstring
    weekstring
    daystring
    hourstring
    minutestring
    secondstring
    timeZoneNamestring
    asNumberboolean
    asOnOffboolean
    asOpenClosedboolean
    asMomentaryboolean
    multilineboolean
    unitsstring[]
