Working on UI and apps
Overview
Working on an app (e.g. Manager UI)
From the main directory, start the required containers, use dev-ui.yml for example:
docker-compose -f profile/dev-ui.yml up -dBy default, this makes the manager container serve the apps present in the latest docker image on port 8080 e.g.
http://localhost:8080/manager/. While these apps are not necessary for this case, the included manager container webservice is. -
cdinto the app directory e.g.ui/app/managerand run the followingnpmscript:npm run serve
Webpack dev server environment variables
The following environment variables can be set when running npm run serve using the syntax npm run serve -- --env ENV_NAME=ENV_VALUE:
- config - To apply a custom
manager_config.jsonyou can set theconfigenvironment variable on thenpm run servecommand using a path relative to theapp/managerdirectory e.g.- Windows:
npm run serve -- --env config=..\..\..\..\deployment\manager\app - Mac:
npm run serve -- --env config=../../../../deployment/manager/app
- Windows:
- managerUrl - By default webpack dev server expects the manager to be available at
http://localhost:8080but this can be configured for example when running the manager Docker image (e.g.npm run serve -- --env managerUrl=https://localhost) - keycloakUrl - By default Keycloak expects to be available at
managerUrl/authbut this can be configured for example when running the manager Docker image (e.g.npm run serve -- --env keycloakUrl=https://keycloak/auth)
Consuming UI components
UI development
- Front end applications
- Front end components and their demos, shared between applications
- Keycloak theme(s) used in authentication screens
- Run a Manager instance in an IDE (refer to Setting up an IDE)
- Deploy the Manager using a Docker container (refer to UI Development profile)
UI Components & Apps (/ui)
component- Base OpenRemote JS modules and web components (built using Polymer) these are written as ES6 modulesapp- Built-in OpenRemote web applications (applications can be built with whatever frameworks/libraries are desired)demo- Demos of each web component (provides a development harness for developers working on the components)
clean- Cleans up any build artefacts (typically uses theshxpackage)build- Build the component/app ready for publishing/deploymenttest- Run any automated testsmodelWatch- Starts agradletask to watch thejavamodel code and to run thetypescriptgenerator when changes are detected, the generatedmodelandrestclienttypescript code is then transpiled tojavascriptmodelBuild- Similar tomodelWatchbut just does a onetime build rather than watching for changesserve- Startswebpack dev servertypically onhttp://localhost:9000/[app|demo]/
Running Manager UI against remote instance
- Add
https://localhost/*to Valid redirect URIs of openremote client in master realm of remote instance keycloak - Ensure remote instance manager container has
localhostlisted inOR_ADDITIONAL_HOSTNAMES(note this variable is comma separated list of hostnames) - Run the
dev-proxy.ymlcompose profile locally - Access shell in proxy container:
docker exec -it <PROXY_CONTAINER_NAME> ash - Add the following snippets to the proxy config (Press i for insert mode, when finished press Esc then : then wq):
vi /etc/haproxy/haproxy.cfg- Above the
use_backend manager_backendline
- Above the
acl webpack path_beg /manager
- Above the
backend manager_backendline:
- Ctrl/Cmd-D to exit the proxy container shell
- Start the webpack dev server in the
ui/app/manager:npm run serve -- --env managerUrl=https://demo.openremote.app
Components
Maps
Apps
Demos
