Retrieve client roles for the currently authenticated user using a client ID
GET/user/userRoles/:clientId
clientId stringrequired
descriptionstring
compositeboolean
assignedboolean
compositeRoleIdsstring[]
    "description": "string",
    "composite": true,
    "assigned": true,
    "compositeRoleIds": [
      "string"
