Version: 1.2.0
Update roles for a realm
PUT
https://demo.openremote.io/api/master/user/:realm/roles
array
  • Array [
  • idstring
    descriptionstring
    compositeboolean
    assignedboolean
    compositeRoleIdsstring[]
    any
curl -L -X PUT 'https://demo.openremote.io/api/master/user/:realm/roles' \
-d '[
"description": "string",
"composite": true,
"assigned": true,
"compositeRoleIds": [
"string"
Request Collapse all
Base URL
Auth
Parameters
— pathrequired
— header
— header
— header
    "composite": true,
    "assigned": true,
      "string"
