Create an alarm
POST/alarm
Create an alarm
Possible values: [LOW, MEDIUM, HIGH]
Possible values: [OPEN, ACKNOWLEDGED, IN_PROGRESS, RESOLVED, CLOSED]
Possible values: [MANUAL, CLIENT, GLOBAL_RULESET, REALM_RULESET, ASSET_RULESET, AGENT]
asset
"id": 0,
"title": "string",
"content": "string",
"severity": "LOW",
"status": "OPEN",
"source": "MANUAL",
"sourceId": "string",
"sourceUsername": "string",
"acknowledgedOn": "2024-07-29T15:51:28.071Z",
"assigneeId": "string",
"assigneeUsername": "string",
"asset": [
"accessPublicRead": true,
"parentId": "string",
"type": "string",
"path": [
"string"
"delegate": {}
