Create an alarm
POST/alarm
Create an alarm
Possible values: [LOW, MEDIUM, HIGH]
Possible values: [OPEN, ACKNOWLEDGED, IN_PROGRESS, RESOLVED, CLOSED]
Possible values: [MANUAL, CLIENT, GLOBAL_RULESET, REALM_RULESET, ASSET_RULESET, AGENT]
asset
