Version: 1.2.0
Delete assets
DELETE
https://demo.openremote.io/api/master/asset
Delete assets
    assetId string[]
    any
curl -L -X DELETE 'https://demo.openremote.io/api/master/asset' \
Request Collapse all
Base URL
Auth
Parameters
— query
— header
— header
— header
