Retrieve assets using a query
POST/asset/query
select
Possible values: [PRIVATE, PROTECTED, PUBLIC]
names
parents
paths
realm
Possible values: [AND, OR]
items
name
value
name
value
previousValue
orderBy
Possible values: [CREATED_ON, FIRST_NAME, LAST_NAME, USERNAME, EMAIL]
    "accessPublicRead": true,
    "parentId": "string",
    "type": "string",
    "path": [
      "string"
      "delegate": {}
