Write to a single attribute with a timestamp
PUThttps://demo.openremote.io/api/master/asset/:assetId/attribute/:attributeName/:timestamp
assetId stringrequired
attributeName stringrequired
timestamp int64required
The result of the write operation
ref
failurestring
Possible values: [ASSET_NOT_FOUND
, ATTRIBUTE_NOT_FOUND
, INSUFFICIENT_ACCESS
, INVALID_VALUE
, INTERCEPTOR_FAILURE
, STATE_STORAGE_FAILED
, CANNOT_PROCESS
, QUEUE_FULL
, UNKNOWN
, ASSET_ID_MISSING
, ATTRIBUTE_NAME_MISSING
"ref": {
"id": "7Bt8M3cXEP6BHPh8r47DYf",
"name": "location"
"failure": "ASSET_NOT_FOUND"
curl -L -X PUT 'https://demo.openremote.io/api/master/asset/:assetId/attribute/:attributeName/:timestamp' \
-d '{}'
