Retrieve the gateway tunnel information of tunnel for a gateway in a realm
GET/gateway/tunnel/:realm/:id/:target/:targetPort
id stringrequired
target stringrequired
targetPort int32required
gatewayIdstring
targetPortint32
targetstring
assignedPortint32
hostnamestring
typestring
Possible values: [HTTPS, HTTP, TCP]
autoCloseTimedate-time
