Retrieve the active gateway tunnel information of gateway in a realm
GET/gateway/tunnel/:realm/:id
id stringrequired
gatewayIdstring
targetPortint32
targetstring
assignedPortint32
hostnamestring
typestring
Possible values: [HTTPS, HTTP, TCP]
autoCloseTimedate-time
"gatewayId": "string",
"targetPort": 0,
"target": "string",
"assignedPort": 0,
"hostname": "string",
"type": "HTTPS",
"autoCloseTime": "2024-07-29T15:51:28.071Z",
"id": "string"
