Retrieve all alarms or a subset using filter criteria
GET/alarm
Possible values: [OPEN, ACKNOWLEDGED, IN_PROGRESS, RESOLVED, CLOSED]
Possible values: [LOW, MEDIUM, HIGH]
Possible values: [MANUAL, CLIENT, GLOBAL_RULESET, REALM_RULESET, ASSET_RULESET, AGENT]
asset
    "id": 0,
    "title": "string",
    "content": "string",
    "severity": "LOW",
    "status": "OPEN",
    "source": "MANUAL",
    "sourceId": "string",
    "sourceUsername": "string",
    "acknowledgedOn": "2024-07-29T15:51:28.071Z",
    "assigneeId": "string",
    "assigneeUsername": "string",
    "asset": [
        "accessPublicRead": true,
        "parentId": "string",
        "type": "string",
        "path": [
          "string"
          "delegate": {}
