Version: 1.2.0
Retrieve the asset links of an alarm
GET
https://demo.openremote.io/api/master/alarm/:alarmId/assets
    alarmId int64required
    realm string
  • Array [
  • id
    userIdstring
    assetIdstring
    assetNamestring
    parentAssetNamestring
curl -L 'https://demo.openremote.io/api/master/alarm/:alarmId/assets' \
Request Collapse all
Base URL
Auth
Parameters
— pathrequired
— query
— header
— header
— header
