Retrieve all accessible dashboards
GET/dashboard/all/:realm
realmstringrequired
ownerIdstring
viewAccessstring
editAccessstring
displayNamestringrequired
template
required
columnsint32
Possible values: >= 1
maxScreenWidthint32
refreshIntervalstring
screenPresets
required
breakpointint32
scalingPresetstringrequired
redirectDashboardIdstring
widgets
gridItem
required
xint32
yint32
wint32
hint32
minHint32
minWint32
minPixelHint32
minPixelWint32
noResizeboolean
noMoveboolean
lockedboolean
widgetTypeIdstringrequired
widgetConfigobject
    "ownerId": "string",
    "viewAccess": "PUBLIC",
    "editAccess": "PUBLIC",
    "displayName": "string",
    "template": {
      "columns": 0,
      "maxScreenWidth": 0,
      "refreshInterval": "OFF",
      "screenPresets": [
          "breakpoint": 0,
          "scalingPreset": "WRAP_TO_SINGLE_COLUMN",
          "redirectDashboardId": "string"
      "widgets": [
          "gridItem": {
            "x": 0,
            "y": 0,
            "w": 0,
            "h": 0,
            "minH": 0,
            "minW": 0,
            "minPixelH": 0,
            "minPixelW": 0,
            "noResize": true,
            "noMove": true,
            "locked": true
          "widgetTypeId": "string",
          "widgetConfig": {}
