Retrieve a dashboard
GET/dashboard/:realm/:dashboardId
dashboardId stringrequired
realmstringrequired
ownerIdstring
viewAccessstring
editAccessstring
displayNamestringrequired
template
required
columnsint32
Possible values: >= 1
maxScreenWidthint32
refreshIntervalstring
screenPresets
required
breakpointint32
scalingPresetstringrequired
redirectDashboardIdstring
widgets
gridItem
required
xint32
yint32
wint32
hint32
minHint32
minWint32
minPixelHint32
minPixelWint32
noResizeboolean
noMoveboolean
lockedboolean
widgetTypeIdstringrequired
widgetConfigobject
  "ownerId": "string",
  "viewAccess": "PUBLIC",
  "editAccess": "PUBLIC",
  "displayName": "string",
  "template": {
    "columns": 0,
    "maxScreenWidth": 0,
    "refreshInterval": "OFF",
    "screenPresets": [
        "breakpoint": 0,
        "scalingPreset": "WRAP_TO_SINGLE_COLUMN",
        "redirectDashboardId": "string"
    "widgets": [
        "gridItem": {
          "x": 0,
          "y": 0,
          "w": 0,
          "h": 0,
          "minH": 0,
          "minW": 0,
          "minPixelH": 0,
          "minPixelW": 0,
          "noResize": true,
          "noMove": true,
          "locked": true
        "widgetTypeId": "string",
        "widgetConfig": {}
