Update a dashboard
PUT/dashboard
Update a dashboard
template
required
Possible values: >= 1
screenPresets
required
widgets
gridItem
required
template
required
screenPresets
required
widgets
gridItem
required
"ownerId": "string",
"viewAccess": "PUBLIC",
"editAccess": "PUBLIC",
"displayName": "string",
"template": {
"columns": 0,
"maxScreenWidth": 0,
"refreshInterval": "OFF",
"screenPresets": [
"breakpoint": 0,
"scalingPreset": "WRAP_TO_SINGLE_COLUMN",
"redirectDashboardId": "string"
"widgets": [
"gridItem": {
"x": 0,
"y": 0,
"w": 0,
"h": 0,
"minH": 0,
"minW": 0,
"minPixelH": 0,
"minPixelW": 0,
"noResize": true,
"noMove": true,
"locked": true
"widgetTypeId": "string",
"widgetConfig": {}
