Retrieve the gateway connections of all realms
GET/gateway/connection
Possible values: >= 1 and <= 65536
Possible values: >= 36 characters and <= 36 characters
attributeFilters
matcher
select
Possible values: [PRIVATE, PROTECTED, PUBLIC]
names
parents
paths
realm
Possible values: [AND, OR]
items
name
value
name
value
previousValue
orderBy
Possible values: [CREATED_ON, FIRST_NAME, LAST_NAME, USERNAME, EMAIL]
assetSyncRules
GatewayAssetSyncRule
excludeAttributeMeta
string[]
string
addAttributeMeta
MetaMap
