Retrieve sessions for a user in a realm
GEThttps://demo.openremote.io/api/master/user/:realm/userSessions/:userId
userId stringrequired
- Example (auto)
IDstring
usernamestring
startTimeMillisint64
remoteAddressstring
"ID": "string",
"username": "string",
"startTimeMillis": 0,
"remoteAddress": "string"
curl -L 'https://demo.openremote.io/api/master/user/:realm/userSessions/:userId' \
