Gateway tunnelling setup
This guide describes the steps necessary to setup the gateway tunnelling functionality which allows remote access to edge gateways using SISH
Edge Instance Setup​
SSH keys​
  • mkdir -p deployment/sish/pubkeys deployment/sish/client deployment/sish/keys
  • ssh-keygen -t ed25519 -b 4096 -f client
  • mv client.pub deployment/sish/pubkeys
  • mv client deployment/sish/client (this will be needed by the edge instances) - Optionally encrypt this file using gradle task
  • ssh-keygen -t ed25519 -b 4096 -f server_key
  • mv server_key deployment/sish/keys
Docker environment variables​
  • Set Keycloak container environment variables:
    • KEYCLOAK_ISSUER_BASE_URI: https://${OR_HOSTNAME}/auth
    • KC_HOSTNAME: This must be blank or completely removed (i.e. do not set this environment variable)
    • KC_HOSTNAME_STRICT: false
  • Set manager environment variables:
    • OR_WEBSERVER_ALLOWED_ORIGINS: *
    • OR_GATEWAY_TUNNEL_SSH_KEY_FILE: <PATH_TO_PUBLIC_SISH_KEY> (/deployment/sish/client/cert)
    • OR_GATEWAY_TUNNEL_AUTO_CLOSE_MINUTES: <MINUTES> This optional variable can be set to automatically close tunnels after the specified number of minutes. When it is set to 0 (or not set) tunnels remain open until they are manually closed.
Central Instance Setup​
  • Proxy container must be able to read/write Route53 DNS TXT record (see https://certbot-dns-route53.readthedocs.io/), this requires the instance to have the required permissions to the Route53 account where the DNS zone is hosted, if the hosted zone is in the same account as the EC2 instance then the standard ec2-access IAM profile that is attached to all our EC2 instances already contains the required permissions so no action is needed, alternatively if the hosted zone is in a different account to the EC2 instance then it is important that the EC2 instance cloudformation template parameter DNSHostedZoneRoleArn was correctly set, this will then get set as AWS_ROUTE53_ROLE in /etc/environment and the proxy container will output this to ~/.aws/config during startup which will allow the plugin to assume that role for Route53 calls. The AWS_ROUTE53_ROLE can alternatively be defined via env file or within the docker compose file itself (NOTE: this role must be assumable by the ec2-access policy)
  • Set DOMAINNAMES to include wildcard certificate e.g. *.example.openremote.app
  • Add wildcard DNS A/AAAA record(s) e.g. *.example.openremote.app
  • Uncomment/add sish service in Docker Compose profile
  • Set SISH_HOST and SISH_PORT on proxy container
  • Set OR_GATEWAY_TUNNEL* environment variables on manager container
  • Set TCP port range in sish service (to allow raw TCP tunnelling)
  • Allow inbound access to port 2222 and to the TCP port range exposed on the instance
  • Generate or select existing SSH private key and add this to the deployment image and set SISH variable: --private-keys-directory
Gateway Tunnelling Development Setup
To debug/develop gateway related code two instances of the manager will be running, one for the edge gateway and one for the central instance. Depending on what you wish to test either or both could be launched from an IDE or you could configure either to allow remote debugging using JAVA_TOOL_OPTIONS and exposing assigned port on the manager docker services (ensure you set 2 different ports if running both managers on the same host).
You need to setup the SSH keys as described in the "Edge Instance Setup" section above.
Either use the dev-proxy.yml compose file and then run the manager in an IDE, or run a compose file with a full stack of services and ensure the manager is configured for remote debugging (unless you don't intend to do any central instance code debugging/development), Run the manager with the following env variables:
  • In the proxy service:
    • SISH_PORT: 8090
    • SISH_HOST: sish
  • In the manager service/IDE:
    • Add 8008:8008 to allow attaching the debugger from the IDE (if not running in an IDE)
    • Optionally, set the manager to be built from context ./manager/build/install/manager, so that code changes are reflected during Docker image rebuild (after running ./gradlew clean installDist)
    • Add JAVA_TOOL_OPTIONS: "-agentlib:jdwp=transport=dt_socket,server=y,suspend=n,address=*:8008" to allow remote debugging from the IDE (if not running in an IDE)
    • OR_HOSTNAME=localhost
    • OR_METRICS_ENABLED: false
    • OR_GATEWAY_TUNNEL_SSH_HOSTNAME: "localhost"
    • OR_GATEWAY_TUNNEL_SSH_PORT: 2222
    • OR_GATEWAY_TUNNEL_TCP_START: 9000
    • OR_GATEWAY_TUNNEL_HOSTNAME: "localhost"
    • OR_GATEWAY_TUNNEL_AUTO_CLOSE_MINUTES: 2 <-- OPTIONAL if auto closure of tunnels is desired
  • Add the sish service, as found in deploy.yml, and modify:
    • Add volume ./deployment:/deployment so that you can map the SSH keys that were generated above
The routing of requests from the central instance to the gateway looks like this: Central Instance --> Sish --> Gateway Proxy --> Keycloak/Manager
For the "Sish --> Gateway Proxy" requests to be routed correctly, we need to either have DNS wildcard support or we have to manually edit the local /etc/hosts file to route the \<tunnelID\>.\<tunnelSSHHost\> to localhost, like this:
127.0.0.1 gw-5fj1sxvwwfp7wvgqgve91n.localhost
The above setup should make the org.openremote.test.gateway.GatewayTest#Gateway Tunnelling Edge Gateway Integration test pass when run from the IDE or via Gradle.
